Police style pattern
I’m trying to make a custom mod to blink every other led red, then blue and the remaining leds do the opposite. fairly fast blink rate. a random led should flash bright white randomly. i have 4 drone arms with 5 leds each…i’m using an esp32 c3 super mini board…
I looked through all of what was available in the menu, and I did not see anything that gets close to what I’m wanting to do. It’s for a father and son drone project with my 6 year old. he knows nothing of this extra bit im adding to the drone…i’m planning on triggering it from the receiver or flight controller via a 3 way switch on my transmitter. i want this to be one of the modes for the leds. the other will be solid green on the front two arms and red on the rear to help him learn flying.
See: Effects - WLED Project
… and search for Police. You can use segment’s grouping to combine 5 physical LEDs into 1 virtual.
For random white LED add an overlapping segment with either Blink or Gitter.
Police effect was retired…so i cant use that. Do you have to use premade effects? Or can you make one?
Please read the article again. And the comment about Police and Police All effects.
