I’m having an issue with my WLED (v16.0.1) setup. I have 4 LED strips split into 2 segments each, giving me a total of 8 segments, plus a physical wall button.
Currently, it works as expected: when I press the button, the light slowly lights up from the corners to the center and stays on. When I press the button again, it slowly dims from the center back to the corners.
The issue happens after a reboot or power outage. When power is restored, the button stops working, and I have to open the app or web GUI to manually click the turn-on preset and the preset assigned to the button. After doing that, everything works properly again.
- Do you have any idea how to fix this?
- Is it possible to configure the wall button so that a short press toggles the light on/off, a double press triggers a random effect, and long-holding it adjusts the brightness (dimming/brightening)?
Here are my presets:
1. On/Off Pushbutton
win&T=2
2. On swipe right
{“on”:true,“bri”:255,“transition”:50,“bs”:2,“mainseg”:0,“seg”:[{“id”:0,“start”:0,“stop”:73,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:1,“start”:74,“stop”:146,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:2,“start”:147,“stop”:294,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:3,“start”:295,“stop”:442,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:4,“start”:443,“stop”:515,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:5,“start”:516,“stop”:588,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:6,“start”:589,“stop”:735,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:7,“start”:735,“stop”:882,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]}
3. Off swipe left
{“on”:true,“bri”:255,“transition”:50,“bs”:3,“mainseg”:0,“seg”:[{“id”:0,“start”:0,“stop”:73,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:1,“start”:74,“stop”:146,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:2,“start”:147,“stop”:294,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:3,“start”:295,“stop”:442,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:4,“start”:443,“stop”:515,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:5,“start”:516,“stop”:588,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:6,“start”:589,“stop”:735,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:true,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“id”:7,“start”:735,“stop”:882,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“lc”:1,“n”:“”,“col”:[[255,255,255,0],[0,0,0,0],[0,0,0,0]],“fx”:0,“sx”:128,“ix”:128,“pal”:11,“c1”:128,“c2”:128,“c3”:16,“sel”:false,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0,“bm”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]}
