Hi. I set up a push button.
If I leave long and double at 0
a long press changes the brightness from current to max. A second long press dims it from max to min. If I replace 0 with a non-existent preset, the brightness is not changed, and the button works as expected.
If that’s expected, it should be documented, otherwise it’s a bug that might need fixing.
