Thanks for the amazing app. But there is one problem with sending images to wled.
I used /pxmagic.htm
For example: i send pumpkin pic, is ok. And for the experiment, an image with two stripes of different colors. The result is in the attached file.
While your post subject is “Pxmagic image crashes” you showed a picture that it is working and you mentioned “all other effects work fine. Again, except for the running text.”
What is the issue you are facing exactly , on which build version and is it with scrolling text or Pxmagic
In the second example(image with stripes), but when export to the matrix, they alternate colors. Why?
Okay, one more example. I drew a pixelated “off”, when send to the matrix pic it crashes (displayed incorrectly).
(build 2310130)
