If that is the exact part # of the level shifter used, that’s the problem. It is too slow for your LED strip. I believe the part # you want is 74HCT125N
Thank you very much for your answer. I will order some 74AHCT125D (SMD part). The propagation delay is 7 to 9 nanoseconds, while the HCT is only 30 nanoseconds.
The 74HCT125N is the DIP package. The board I designed uses SMD components.
Yes they are. :-). But I will check my solder joins just to be sure. But at the moment, all the effects are working well. I notice that I have two (2) LEDs out of the 100 that are defective. They might also be involved in this problem. Who knows.
If you find that someone had the same problem, please let me know.
