Question on 3d fx
Hi everybody. With the addition of geq 3d… I’m e ited to think that wled fx are moving into the 3rd dimension lol…
Using the GEQ 3D STYLE
Can the following effect be modified for 3d similar to it?
Fireworks audio
Funky plank
Gravcentric
Matripix
All fx that operate in the way these do
And and that will look cool 3d
Now I’m without the skills required… But I’m sure there are people here that could wack these up in a minute.
PS Idea for GEQ 3D 2
Exactly as it is but the don’t return… FX fade out into the “distance”?
Hope you get the idea and directions of my thoughts…
Thanks for reading…
you may provide better base infos
did you like to go for a 3D matrix like CUBE style or a based Trasparent 3Dprinted logo
there are so many options on this style
what place is it in or outdoor so the light and source decision
Daylight or night display
cheep woudt be a Nodemcu and a stripe like D1 5USD and 1m/30Node at 3USD will make you a projekt
I’m sorry if I didn’t make it clear…
Though your assumption is still a valid path and in time I will do a psysical realnworld 3d object around wled.
But my question or thought were about the presets within moonmodules/wled… Namely GEQ 3D and if any of the other fx can be ported to 3D in the same way.
