Random flicker with sacrifice pixel
Hi together,
i`m currently building my first setup with the goal to have 4 Stripes (40,18,121/121 LEDs) connected to a ESP32WROOM Devboard.
I’ve been struggling with random flicker in one or multiple stripes. Since then i`ve improved my built and even printed holders for the sacrifice pixels to have them more stable but the problem remains - even if it got better.
With only one stripe everything seems normal but after attaching more, the problem began.
What i have: 5m BTF WS2812B eco already cut to the needed length all wired up with AWG16 wire.
Each channel has a sac. pixel on the dataline in between around 15cm after the GPIO.
I did a lot of resoldering and changing stripes and sacrifice pixels since the beginning. Even a new power supply with 5v/30A (before 5V/5,5A but only for 60 pixels).
The only thing that is really unchanged since the beginning, is the ESP.
So today a new ESP arrives and i will check with that but maybe you can give me a hint if i did anything fundamentally wrong.
I`ll attach some pictures and a wiring diagramm.
Thank you.
best
Johannes
I dont see the diode for the sacrificial pixel.
also, this is a high speed signal, not your 50Hz house installation, keep ground loops tight or its very prone to flickering.
is there a Special Diode I should use?
And what do you mean with ground Loops?
yes you need a diode, otherwise its useless. also sacrificial pixel is a poor solution, use a proper shifter.
for loop check wiring diagrams in wled knowledge base.
I would get rid of those sac’ pixels and use a SN74AHCT125 levelshifter. You may also need a resistor on each data line. I could be wrong, but it sounded like you were not too into soldering so this shifter may be a little easier than the bare chip from above: Level Shifters - SN74AHCT125 (Pack of 4) – RGB 2 Go
If you are set on using those sac’ pixels I would try adding a resistor after them. What value? That is debatable. Something between 33ohm and 300ohm likely. I would try either 33 or 249
thanks for your answers. I really appreciate it.
As I understood, to have a clean solution I would go with this one, right?
https://www.berrybase.de/sn74ahct125n-quad-level-shifter-dil-14
I would also buy a socket and solder the esp to a circuit board.
I would also use this connectors for 24v and data outputs
https://www.berrybase.de/anschlussklemme-schraubbar-900-gewinkelt-2-50mm2-rm-5-08mm-2-polig
Would that be ok?
And I would also go with the resistors 33 - 200 Ohm and the capacitor as seen in “Multi LED Strip Wiringdiagram” here
https://kno.wled.ge/basics/wiring-guides/
Thank you
That is the correct levelshifter you linked to. Also note you need the 100nF (.1uF) Ceramic bypass capacitor that is pictured close to the level shifter. -Not sure if that was the capacitor you said you would add, but that one is needed. If you were talking about the 470uF Electrolytic one by the Esp, that one is a good idea for any power dips but is not an absolute needed item.
If you are going to solder the Esp to a prototype board I would use pin header strips, so that if you ever need to remove the Esp it is as simple as unplugging it.
I’m in the USA so navigating that site you are looking to buy from is kinda hard, but I’m talking about these things soldered to the prototype board and the Esp’s pins plugging into them: Pin header kit for Feather, 12-pin and 16-pin socket connectors - buy at BerryBase
I am not sure what you are wanting the screw terminals for when referring to “24v”. Your prior pic shows you have a 5v 30a power supply :face_with_raised_eyebrow: As for using those screw terminals for the data connections and power to the Esp, they would work fine. *I would not use them for power to your LEDs unless you are sure you will be under whatever their current (amps) rating is.
I made some comments in this other topic that may or may not be of help to you, feel free to have a look Roccomendations for Narrower ESP32 Board - #4 by Jinx
sorry for the confusion, of course im using a 5v/30Amps power supply. The LED-Stripes will be connected on +/- directly from the power supply via WAGO (AWG16). The 5v power will be delivered to my prototype board via the connectors i mentioned.
Also i got this components already here:
I ordered these two and i`m wating for arrival.
Additionally i already got these one here for the connection of the ESP to the board like you mentioned.
I think i got everything to start.
Any recommendations or the wire size for the 5v connections?
Thank you.
Awesome! Looks like you are prepared for your build. 1 tip I would offer would be to triple check that all your connections are correct before connecting power. It can help keep the magic smoke from coming out. :grinning_face_with_smiling_eyes:
