Hello
I have searched and been unable to find anything similar to the issue I am having.
I have multiple devices running WLED with no issues, I have tried to update a couple to version 0.10 , when I did it OTA they did not reappear on the network so I tried flashing via serial and it seems to wrok until I enter my wifi details, then they just end up rebooting every couple of seconds. I’ve tried going back to 0.91 and the same thing happens so I am totally confused as to what is going wrong.
I’ve tried erasing the flash using esptool.py, flashing via esptool.py and ESPhomeflasher and the result is the same every time, device is stable until I enter my wifi details then constant reboots.
I am having issues with three D1 minis now, all showing the same behaviour.
ESPHomeflasher view logs shows below over and over but I have no idea what it means
Using ‘/dev/cu.wchusbserial1420’ as serial port.
Showing logs:
[19:42:16]
[19:42:16]Exceptio 8)
Serial port closed!
[19:42:16]p1=0x0pc3=0000 excvaddr=0x00000000 depc=0x00000000
[19:42:16]
[19:42:16]>>>stack>>>
[19:42:16]
[19:42:16]ctx: cont
[19:42:16]sp: 3ffffd30 end: 3fffffc0 offset: 01a0
[19:42:16]3ffffed0: 00000000 00000001 3fff1f34 3fff2398
[19:42:16]3ffffee0: 3fffff40 3fffff4c 00000000 402228e3
[19:42:16]3ffffef0: 00000050 00000005 3fffff20 3fff2170
[19:42:16]3fffff00: 00000003 3fff2378 3fff184c 3fffff4c
[19:42:16]3fffff10: 3fffff40 00000050 3fff2398 4022294e
[19:42:16]3fffff20: 3ffeabd3 3fffff40 3ffeabcf 3fff2170
[19:42:16]3fffff30: 3ffeabd3 3ffeabcf 3fff2398 4021c07e
[19:42:16]3fffff40: 00706374 f000a8c0 83c6a7f0 64656c77
[19:42:16]3fffff50: 3fff5400 842210bc 40100b30 3fff2170
[19:42:16]3fffff60: 3fff2175 3fff216f 00000000 4021c2de
[19:42:16]3fffff70: 00000000 402210bc 3fff2598 3fff25d8
[19:42:16]3fffff80: 00000000 00000000 00000001 3fff25d8
[19:42:16]3fffff90: 3fffdad0 00000000 3fff2598 4021f3e7
[19:42:16]3fffffa0: feefeffe feefeffe feefeffe 402304c4
[19:42:16]3fffffb0: feefeffe feefeffe 3ffe8800 4010089d
[19:42:16]<<<stack<<<
[19:42:16]
[19:42:16] ets Jan 8 2013,rst cause:2, boot mode:(3,6)
[19:42:16]
[19:42:16]load 0x4010f000, len 1384, room 16
[19:42:16]tail 8
[19:42:16]chksum 0x2d
[19:42:16]csum 0x2d
[19:42:16]vbc204a9b
[19:42:16]~ld
[19:42:16]Ada
Any ideas?
Alex
Glad to be of help in here…
