Home Assistant FTW!
The bottom three buttons do all the work - the right button is ‘Restart’ (a standard part of the HA WLED integration) - this has to be pressed after toggling between line-in and mic.
The left (line-in) and centre (microphone) buttons make calls to rest commands in configuration.yaml:
rest_command:
wled_line_in:
url: "http://{{url}}/json/cfg"
method: post
content_type: 'application/json; charset=utf-8'
payload: '{
"um": {
"AudioReactive": {
"digitalmic": {
"type": 4,
"pin": [
35,
25,
27,
0,
-1,
-1
wled_microphone:
method: post
payload: '{
"um": {
"AudioReactive": {
"digitalmic": {
"type": 1,
"pin": [
26,
5,
21,
0,
-1,
-1
Just add your WLED url as service data
service_data:
url: 192.x.x.x
under the ‘service:’ line in the UI Button card.
This now does what I need it to do so won’t be pursuing the physical button route.
Thank you for your help & guidance.
P.S. It says ‘SoundReactive’ on the buttons but I’m running MM v0.14.1-beta.30 as above.
