It is a chip that uses mbi6033 dta+clk, added to the neopixelbus library. I’ve come to a certain point by making some changes to the wled code. But I can’t solve flickering and empty color bytes.
mbi6033 asks for header information first and then uses 48 bit color. In the form of G 16 + B16 + R16. However, the first large byte of this 16-bit is always empty. I added in the picture.
The method we used in the bus_wrapper section was added this way.
#define B_HS_DOT_3 NeoPixelBusLg<NeoRbg48Feature, Mbi6033Method, NeoGammaNullMethod>
