Hi, if i am starting my nightlight with mqtt like
'{"ps":4,"bri":255,"nl":{"on":true}}'
it works well if id 4 is a preset. But with a defined playlist i have no success, it just show a solid color. The playlist itself works when triggered e.g. by the app.
Is there any difference in starting playlist to presets with the json syntax ?
I think the playlist/presets are still referenced internally via index#. I don’t believe you can use the nice human labels from outside.
Might be able to create a cross-ref in your MQTT code ?
No, i never used the human labels. As shown above i am using the index 4
Sorry I misread your original. At little searching on the forum turned up:
{“on”:true,“playlist”:{“ps”:[1],“dur”:[100],“transition”:7,“repeat”:1}
As an example of a playlist call where Preset 1 is a playlist. I’m sure there are more fine details to lock down, but that should get you started.
