I have a playlist of several presets that run most of the evening. Late at night, I have the timer set to start the preset below for overnight. Only the brightness is actually applied. It might switch to this effect initially, but I always find that the lights are still cycling through the previous playlist, just at the lower brightness. Why does it not stay with this effect?
To be clear, I created both the playlist and this effect by saving states and using the playlist editor, not editing the code directly. I’m using v0.13.0-b5.
Thanks for the help!
{“on”:true,“bri”:16,“transition”:30,“mainseg”:0,“seg”:[{“id”:0,“grp”:1,“spc”:0,“on”:true,“bri”:64,“col”:[[255,0,255],[0,0,255],[255,255,255]],“fx”:106,“sx”:128,“ix”:128,“pal”:5,“sel”:true,“rev”:false,“mi”:false}]}
