Hi everyone,
I’m hoping someone can help me troubleshoot a very persistent issue with my WLED installation.
Hardware
Controller: GLEDOPTO ESP32 WLED controller
WLED: Latest stable version
Signal amplifier: GLEDOPTO WLED Signal Amplifier (installed on Output 1)
Power supply: Mean Well UHP-350-5 (5V, 70A, 350W)
LEDs: SK6812 RGBW (5V)
Installation
Total LEDs: 1677
The controller has 2 independent outputs.
Output 1
Island 1
Island 2
Island 3
Approximately 800 LEDs total.
A GLEDOPTO signal amplifier is installed directly after the controller before Island 1.
Output 2
Island 4
Island 5
Island 6
Island 7
Island 8
Approximately 877 LEDs total.
Both outputs are powered directly from the PSU and share a common ground.
Main issue
Most animations work perfectly.
However, with some heavier animations (for example color chase animations where almost all LEDs are active), I get a subtle brightness flicker.
Originally I suspected the PSU, so I replaced my generic 5V 40A power supply with a Mean Well UHP-350-5 (5V, 70A).
Replacing the PSU made absolutely no difference.
Initially I thought both outputs flickered perfectly synchronized, but after observing more carefully this doesn’t always seem to be the case.
Sometimes:
only Output 1 flickers
only Output 2 flickers
sometimes both
The flicker is subtle. The controller does not reboot and the LEDs do not completely reset.
Additional issue
Yesterday I resoldered the data connection going into Island 2 because it had been showing corrupted colours.
After resoldering, everything appeared to work correctly.
However, around 4 AM I was woken up because the first few LEDs on Island 2 suddenly turned on bright white by themselves.
At that moment:
WLED was OFF
no animation was running
no commands had been sent
The only way to turn them off was to disconnect power from the PSU.
This morning I powered the installation back on.
The white LEDs were gone again and all normal animations worked correctly, except for the heavier animations that still produce the subtle flicker.
So this issue appears to be intermittent rather than permanent.
Things I’ve already tested
Replaced the power supply with a Mean Well UHP-350-5
Replaced the transport cable between Island 1 and Island 2
Verified continuity on all three conductors of the transport cable
Measured 4.88V directly on the input pads of Island 2
Bypassing Island 2 allows Island 3 to work correctly
Resoldering the data connection into Island 2 greatly improved the previous corruption issue
Signal amplifier installed before Island 1
One thing that confuses me is that the problems seem to appear and disappear without me touching the hardware. The installation can work perfectly for days or even weeks before the issue suddenly returns.
Questions
Has anyone seen this type of subtle flicker on larger SK6812 installations?
Since replacing the PSU made absolutely no difference, what would you investigate next?
Has anyone experienced LEDs turning on by themselves while WLED is OFF?
Could this be related to the GLEDOPTO controller, the signal amplifier, grounding, or signal integrity?
I’ve been troubleshooting this installation for several weeks, so at this point I’m trying to understand the root cause rather than continue replacing parts randomly.
Any ideas would be greatly appreciated.
