TERMINAL API Curl Variable commands
id like to share some infos on Direct NET Commands
here a example on CURL using VARiables and integration via JQ (jq)
Example standard 30LED Stripe
FIRST lets set the top 15 LED on GREEN (0,255,0) and the others14-30 OFF Black
curl -X POST "http://YOUR WLED IP/json/state" -d '{"on":true, "bri":25, "seg":{"i":[
        0,15,[0,0,0],14,30,[0,255,0]]}}' -H "Content-Type: application/json"
then use a for loop to make a Hourglas effect
led=1;for x in {0..14..1}; do r=$(jq -cn --arg led "$led" '($led|tonumber) as $led | {on:true,bri:25,seg:{i:[0,$led,[0,255,0],30-$led,[0,0,0]]}}'); curl -X POST "http://192.168.2.100/json/state" -d $r -H "Content-Type: application/json";echo "nummer $led"; sleep 1;((led++)); done
EXplaining
led=1 is the VARIABLE to be incresed
the Terminal Bash separeter are " ; "
for x in {0…14…1}; this makes the loop 15times 0-14 in steps 1
do —> does the codeblock
r=$(jq -cn --arg led “$led” ‘($led|tonumber) as $led | {on:true,bri:25,seg:{i:[0,$led,[0,255,0],30-$led,[0,0,0]]}}’); —> this is the string to be generaded and passed to the CURL -d Part as -d $r
CURL does the sending to the IP adress of your WLED
have fun with your own sequences
I was doing the same with dos batch file which is helpful to locate the pixel when messing with the mapping
for /l %%x in (0, 1, 44) DO (
curl http://10.0.3.34/json -d  {"seg":{"i":[%%x,[255,255,0]]},"fx":115,"transition":5} -H "Content-Type: application/json"
You are making a usermod ?
@ALDIY No im not making a Usermod on that
And what is interesting the OS does matter on this kind of Action
Unix/Linux does bhave diverent on CURL Batch
Syntay does matter
Okay , just because it is in the usermod title i thought you plan to do a console to control or issue those commands even to other units ( a lot of guys asked for this and if you think about it ,it would be great same as you could do now in Tasmota console or berry scripting )
And yeah i have seen also that the json format is very finicky so from mac or from god forbid HA you would have to mess with the formats specifically the quotes
@ALDIY first at all the main DEVELS shoudt vonsider a BASH preset with USER API commands
like
INIT{ Vars and startsetup}
DO{ THE LOOP here comens the API command}
i think there is somthing like this in JASON but it is not implemented in the DEV
or Simply not Known to puplic
Most users with this kind of ““hobby”” LED expiriances know to do things in ARDUINO IDE
woudt be good to get somthing simple for USERDisplay
