Hi everyone,
at first thanks for the wled firmware, it works like a charm.
But now i have issue with proper setup of wled to work with two different color strips that i would like to control with single button.
Now i have tasmota with this setup: single button that can switch ON/OFF specific led strip on time range. Is is very helpful, because i have white strip that can be switched only between 5:00-19:00 and from 19:00-5:00 it can switch second strip with color PC-Amber.
Then i have set rule to watch whether the white strip is ON when 19:00 occurs and if yes, then it toggle white to OFF and PC-Amber to ON.
I know that i can use two buttons, but i like solution only with one button (it helps prevent switching white strip in the evening - i have CRI98 white strip which can affect circadian rythm).
I dont like tasmota because when i would like to dimm the strip i can see choppy dimming. I am not able to fix that.
