Usermod update for MPU6050; request
Good Morning,
Created a sketch that will create variables: “effects,” “intensity,” and “color pallete” for use with WLED.
OpenAI’s, ChatGPT assisted on the project.
MPU6050_WLED Sketch results
Github repository of MPU6050_WLED project
Short video showing WLED effects, intensity, and color palettes
Struggling at modifing Usermods ; being a newbie to WLED Usermods, is there anyone that could create Usermod for this Sketch. Goal is for this to be user interactive; using a “paddle” with MPU6050 mounted on “paddle,” along with a battery powered ESP32 sending: effects, intensity, and color palettes depending on the MPU6050, Accelometer outputs.
Regards,
William
MPU6050 usermod demo here Discord , might be easier to modify that
@ ALDIY Link has no content on Discord; just Intro page.
William
Demo for that on discord search for MPU6050
Good Morning,
Struggling to figure out a way to keep motion detection active using an interrupt, for sequential data readings; decide on another approach. Using a touch pin with a conditional statement. I have the desired result working.
If the “Chromawand” is in use the motion function is called; when not in use, noMotion function is called. Nearly perfect; except for some math processing time I think, as there is some lag between “Chromawand” movement and seeing the change in RGB effects.
“Chromawand” uses MPU6050, Accelerometer and Gyroscope to send motion data; after conversion to WLED variables. Variables make up a custom URL String; sent by HTTPClient to a WLED Controller. I am sending ny WiFi; from Sketch running on an ESP32. Sketch will also run on an ESP8266.
Project should work with any WLED Controller; since it utilizes the WLED HTTP api. There is no need for a Usermod. Project was developed with an assist from OpenAI’s. ChatGPT.
Code is on GitHub
William
i will get MPU6050 tomorrow if we could test that
Hookup diagram for ESP32 is included in the GitHUb repository.
GitHub repository for project code
William
