Using the WLED current limiter
I have a prototype setup with a benchtop power supply for a 5v LED strip SK6812 RBBW and a computer powering an ESP32.
The strip is 300 LEDs long.
The power calculator says I will need 14A.
Setting this up, with a limit of 10A in WLED, the benchtop supply shows 4.7A at 100% brightness (RGB+W), and WLED estimates 10A.
  1. I am somewhat curious as to why the calculator is so far out. I get that all strips differ, however this is double, and I guess WLED uses similar calculation as its estimate is also double.
  2. The outcome, is that to set a real value of say 5A, I need to set the limit to 10A which doesn’t feel very satisfactory or safe, and without the supply display, I won’t know what is really being drawn, and it could be real 10A which might not be good.
  3. The calc says to put 3 power injections, however there is no drop off in colours, the lights will not go any brighter (as the power supply is capped to 10A also, and is drawing ~5A), so would I really need this?
  4. I can imagine I would if I was putting too many amps through the wires of the strip itself, however there appears to be a recommendation to have one injector at 7.3A so I assume the strip wiring can handle this, and therefore a peak possible draw of 5A is fine?
Any advice greatly appreciated
Dave
Measure single LED color (R or G or B) current when at full brightness, multiply by 3 then by count of pixels. That’s how WLED calculates.
FYI W channel is not taken into account.
Once you have single pixel current consumption use custom value in LED settings.
According to the spec sheet, they are 18w per metre, which is 0.3w per LED, giving 60mA per LED. Multiplying by 300 gives 18A. Or 90w for 5m /5v = 18A
Yet I am only measuring 4.7A at full brightness from benchtop supply.
Is there some impedance on wiring or something that means I should be injecting at both ends to get full brightness?
You need beginning, middle and end supply for 5m 5V.
