I’ve read several posts, seen every diagram, I still have flickering pixels.
Here is my exact wiring diagram and hardware:
I am using the following hardware:
- LE D Pixels - WS2811 (12v) - 50 Nodes
- Meanwell 12v PSU
- WT32-ETH01 running WLED v0.14.1
- Arduino Logic Level Converter (converting 3.3v output of the WT32-ETH01 to 5v expected at the LEDs)
- Chuangruifa DC to DC 12w Step-down converter from 12v to 5v
- 2x 3 Pin Wago Clips
I have tested my solders, they are good.
My preferences in WLED are:
- Enable automati brightness limiter - Off (I have tried on at 500 and 5000, they dont make a difference)
- Hardware setup is WS281x with color order RGB, start 0, Length 50, GPIO 4, Skip First LED off (I have tried on with 1, didn’t work). Off Refresh is off.
Everything else is off, or default with the exception of:
- Use Gamma correction for color is on
- White Balance correction is on
When the WT32-ETH01 is on connected to the LEDs, they do 1 of the following, seems to rotate, or be inconsistant, in the order of what happens most frequently:
- Flicking (flashing, alternating colors)
- Colour selected is not the color I chose, despite knowing my LEDs are RGB order.
- 1 Pixel is randomly a different color
- Multiple pixels are not the same color
I will note though, if I set a colour in WLED web interface, whilst it will flash and what not, if I unplug my WLED, the LEDs will stay that color solid, no issue whatsoever, no flicker, no random color, nothing. It ONLY does it, if I have my WLED connected, I thought possibly that means data? Which is why I got the Logic level converter, but that didn’t do anything.
We are talking like 10 cm from all my cabling to LEDs, its not a long distance, and I’m using 18 gauge wiring throughout.
I can only assume I made a mistake with my wiring somewhere, somehow, despite looking at endless diagrams online.
Please, I’ve spent 3 full days of at least 12 hours each day trying to work this out. I’m a horrid solderer, so 80% of this was attempting to get the thing to stay, but I know for sure, it’s all there now.
The ONLY thing I haven’t done is power injection, it’s 50 pixels, I can’t imagine thats the issue.
PS: I’m not sure if I’m allowed to say this or not, Mods can remove this note if I’m not. I will happily pay someone to work with me here to fix this. My time is far to valuable to be spending 3 days on this, I’ll just pay someone to solve it so I don’t have issues.
