Hi there,
I run WLED 0.10.0 on a NodeMCU v3 and Hyperion 2.0.0-alpha.5 on OSMC on a Vero 4K+ for Kodi. The Hyperion feed is received by WLED for a minute or so. While it does that, the WLED Web UI is not available.
Then WLED seems to drop out of the Hyperion mode, it does not receive the UDP stream any more and just display all LEDs in orange color. Then the WLED Web UI is available again.
When the WLED device is rebooted, the Hyperion mode kicks back in again for a minute or so.
I thought maybe it is the Home Assistant integration on the native WLED API and removed that, but that did not help. I have no sync interfaces active, except for Realtime UDP.
- Any ideas why WLED drops the Hyperion feed after some time?
I found that the Smoothing seems to bog down the Vero so that the controlling of the menus becomes painfully unresponsive. So I turned off the smoothing currently.
The other issue is the lag I am experiencing, changes on the screen are reflected with quite a lag by the WLED NodeMCU v3. The lag happens with video content (Platform capture, automatic) and with many Hyperion effects that have a higher speed. What are reasonable values in Hyperion for:?
LED Refresh time
Latch time
Capture frequency
Hyperion on Vero 4K+ is connected to a managed VLAN, the same VLAN that the WLED NodeMCU is using via WiFi (2.4GHz). Shouldn’t this be fast enough?
- What is the limiting factor here? Vero 4K+? Network? NodeMCU? Number of LEDs (300, SK2812)?
