WLED / LEDFX Music Visualizers and more
New Update v4.2.7 with even More Music Visualizers, performance improvements, bug fixes and so much more. Control WLED, LEDFX, MAGICHOME, Play and record Scenes, Presets, handle Installs and Updates with one click, add custom controls to start WEB URL’s like (Spotify.com) or start Program EXE’s like (WINAMP) all on one screen. Reboot slow devices, Sanitize Presets so brightness settings don’t effect controls in WLEDCC and much more. Have a look and let me know what you think. Releases · PPPAnimal/WLEDCC · GitHub
The color pickers and preset pickers on WLED cards are greyed out in this pic due to LEDFX being in control of them. Click the LIVE badge on card to release LEDFX control of that device only, or click STOP LEDFX to close the background service and return all devices to WLED control.
Note the yellow update button on HOUSE device card. One click will auto download, unzip, and install the correct firmware / software updates for WLED devices, LEDFX program, and WLEDCC itself. If LEDFX is not auto discovered when you try to run it, you will be prompted with a install button or option to browse to its path to teach WLEDCC where to find it next time. One note on device firmware. App only counts latest non-prerelease versions as something to update too. So if you manually upgrade to a alpha or beta version the card will show a update button suggesting you install the older stable version.
NEW FEATURES Added in V4.6.7
Udater fix - Show update button in app even if github latest release info is stale.
SPECTRUM ANALYZER (PC AUDIO)
The header includes a live spectrum analyzer that reacts to your PC audio.
Click the spectrum display or MIC icon to open Spectrum Settings.
idle modes arcade pack: Pac-Man, Tetris, Space Invaders, Snake and more.
SPECTRUM SETTINGS (MODES + TUNING)
SENSITIVITY — Global analyzer gain.
REACTIVITY — How fast bars rise on transients.
BAR DECAY — How fast bars fall.
PEAK DECAY — How fast peak markers fall.
MODE — Classic, VU (L/R), Random (1 min), Random (Per Song).
IDLE EFFECTS — Runs ambient visuals after silence timeout.
IDLE EFFECT OPTIONS — Random, Aurora, Pulse, Text, Rainbow,
Pac-Man, Tetris, Invaders, Snake.
SPECTRUM VISUAL EQ (UI ONLY)
10-band visual EQ is available in Spectrum Settings.
Presets: Flat, Bass+, Smile, Vocal.
Important: This EQ only changes the analyzer visualization in WLEDCC.
It does not change Windows audio output or device audio tone.
LEDFX SCENES MODE
Scene bar can switch between WLED scenes and LedFx scenes.
Use the scene mode toggle button in the scene bar.
When LedFx mode is selected, WLEDCC fetches current scenes from LedFx.
If no scenes are returned, the row shows “No LedFx scenes”.
EXIT POPUP AUTOMATION (BEFORE CLOSING APP)
Auto-run on exit options let you save one-click shutdown behavior:
  • Stop LedFx automatically on exit.
  • Run All Lights Off automatically on exit.
    Startup automation options are also saved here:
  • Auto-start LedFx on app launch.
  • Auto-load last WLED scene.
  • Auto-load last LedFx scene.
CUSTOM CARD AUTOMATION
Custom cards now include per-card automation checkboxes:
  • AUTO START: launches this card target when WLEDCC starts.
  • AUTO CLOSE / STOP ON EXIT: closes target when WLEDCC exits.
SPOTIFY WEB CARD CONTROLS
Spotify web cards show controls for:
  • Previous
  • Play/Pause
  • Next
  • Show Spotify Web UI
    Status line can show now-playing style feedback when available.
WINAMP CARD CONTROLS + SETUP
Winamp cards include controls for:
  • Previous, Play, Pause, Stop, Next
    If winamp.exe path is missing, WLEDCC offers:
  • Install WINAMP (legacy installer)
  • Browse to existing winamp.exe
  • Open Winamp downloads page
DEFAULT QUICK CARDS
On first run, WLEDCC will add default custom cards:
EDIT DEVICE IP
Device IP can be edited directly from the card IP field.
WLEDCC rebinds the device live to the new IP.
Note: some controls may require app restart for full re-bind.
LOG OPTIONS EXPANDED
OPEN LOG now includes additional options:
  • DBG on open (turn debug on when log opens)
  • Auto-open (open log panel at app startup)
  • Save to disk (write current session logs to file)
  • BG updates (continue log/UI updates when app is not focused)
BUG FIXES
  • Brightness sliders were not showing numberical value.
  • Devices now remember last color\brightness between sessions
  • Reduced logs to one per session, 10 Max
  • Last used scene button border now glows
v4.6.9 HOTFIX just dropped for LEDFX sound bug in 2.1.6
Also a few setting options added to v4.6.8 to adjust frame rate etc on Spectrum Analyzer for slower systems.
get the lastest copy here:
UPDATE v4.7.0 Controls your Music App, WLED, LEDFX, MAGIC HOME devices while you chill to several included VU meters, Spectrum Analyzers, or even create your own all from one screen. BEST REMOTE EVER!!!
Check out the latest update, v4.2.7. Many more Music Visualizers Added. Performance Improvements, Bug fixes, and sooo much more.
