I am just starting out. What is the basic underline method WLED uses to recognize other ESP32/86 boards running WLED.
MikeZ
MikeZ
Are you talking about the phone app or syncing between WLED installs?
Hi hugg-d1,
yes. From the videos I have seen, users appear to be able to control different WLED installs from the one app.
MikeZ
the WLED app (or any other device/service on the local network) uses mDNS (also called Bonjour and Zeroconf) to discover WLED instances with the _wled._tcp service type.
Additionally, WLED devices can discover and list other WLED instances via a UDP protocol. You can find these in the instance list (“Nodes” button in the UI, or on mobile devices, “Instance list” in the Info tab)
Hi Aircookie,
Thank you.
MikeZ
