WLED Time for LED off during the day and on in the evening?
I only want to use my Stripe in the evening, after a preset time (also from sunset to sunrise), how can I ensure that the LEDs remain off during the day?
My strips with PIR triggers (as a switch (backed timer 2 minutes)) are connected, which works well so far.
create an off preset and schedule that at the evening (i.e. sunset)
Hi ,
I tried that with the command T=0 ( my present 3 )
entered for test under Timed controlled presents
6 o’clock / 0Min / Present ( Off ) 3
6pm / 0Min / Present 1
and also
Sunrise / Present 3
Sunset Present 1 ( Rainbow )
but unfortunately no success.
there is no 6PM in WLED only 18
So the Hour column stands for the time, doesn’t it? Well unimportant, finding a solution is my endeavor
For 6PM blaz is saying to use 24hr format. 6 would be 18.
6h / 0m / Preset 3
18h / 0m / Preset 1
Since it is supposed to be used for hallway lighting, it does not have to light up during the day, since I use PIR, it should be switched to present 1 from 6 p.m. but remain off until PIR reacts.
from 8 p.m. another present.
Apply Present at Boot is set to 0
Time setup to CET ( Cest ) (Germany)
Presents ( 3 = Off / 1 = Rainbow / 6 = Haloween )
that’s how it’s registered
