Thank you again for your help. I’ve made progress on the project.
Good to see you got it working. When you get that setup how you want it, I would avoid using those dupont breadboard jumpers and switch to decent wire. Those dupont’s are very thin and generally make poor connections.
Yes, of course, it’s a test set-up. The final installation will be done properly. Thank you very much again for your precious help. I’ll do a post of my final installation
Thanks dude! Been 3 hours I’m desperately trying to find a solution, while I simply needed this resistance between signal output and LED strip ! Im still having some flashes sometimes so I will probably increase the resistance value. Thanks again!
