So I’m trying to use the Wordclock usermod.
But the mod’s useage .doc is lacking install tips. And I’m a novice to usermod’s and could use some guidance.
How do I add it to Wled?
I’ve tried to rename the user mod file “word-clock-matrix.cpp” to “usermod.cpp” and place it in the wled dir, overwriteing the existing file.
However this resulted in compilation errors.
wled00\usermod.cpp:22:29: error: 'saveMacro' was not declared in this scope
saveMacro(14, "A=128", false);
So I guess I’m missing something or the mod has not been updated for use with Wled v0.11.0.
Any tips for a novice to use this mod correctly?
Edit: I’ve tried with v0.10.2 and it seems to compile fine. I have not tested as I’m waiting on the led matrix, but I’m assuming it’s fine. So it seems the mod is in need of a update, perhaps?
