WS281x flickering and connection issues
Hi There,
i have some issues with the WS2811 12V LED Strip. I have connected a WS2811 12V LED strip to an ESP32. I use a 12V 3A power supply. The level shifter is a TXS0108. I operate the ESP32 with a separate USB power supply, but I have also tried a step-down module, same result. I use firmware 0.14.2.
Unfortunately the strip flashes wildly in different colors. I have already replaced all the hardware to avoid defects. I have also tested the entire setup with a 5V WS2812b, with the same result.
I seem to have made a mistake somewhere, but I just don’t know where.
I have also attached a circuit diagram.
Does anyone else have an idea? I am really desperate.
Many thanks!
Various folks have had mixed reviews with the TXS devices.
Some are OK, some not so much.
I don’t have major experience with those devices, I prefer the 74AHCT’ stuff if only because they’re single supply.
The suggestions I’d have would be:
Try a dedicated pair of lighter (22-26AWG) data and gnd wires.
Try a dedicated 3.3V supply for the TXS, even just a 5V-3.3V buckconverter for the TXS. Make sure you have a good 5V supply (2A) for the ESP.
Verify there’s common ground between the ESP, power supply(s) and strip
I run !2v lights on a variety of controllers. I have never needed a level shifter, my controllers are all within one metre of the first led. Try bypassing the level shifter and see if that helps.
Alan
As they say:
“There’s 2 types of WLED users -
Those who use a level shifter, and those who will”
Maybe I’ve just been lucky, if it ain’t broke don’t fix it.
Alan
What’s the data wire length between shifter and first LED?
For me the TXS0108 have been OK only up to a couple of meters.
Some strips work without shifter e.g. individual WS2815 pixels but typically not the “groups of 3”.
