I am working on a project where I will have (6-10) light tubes that are 6’ (2m) long. I am using ws2812 currently. I may do some sk6812 as well. 60 LED per meter.
I have already made some 4’ prototypes but I decided to go with a longer tube.
Each tube has its own esp32. Each one will be powered by (3) 21700 molicel p42A cells. 45a discharge, 30a continuous per cell. (Left over from an electric skateboard battery build)
I am currently building the battery packs. I have ordered all the material already, but I wanted to check here to see if there were any better options.
I want the 1s3p pack to
- be easily chargeable
- have over charge protection
- have under voltage protection
- provide as many amps as 2m @60/M will need
I will be spot welding the pack together with kweld and nickel strips.
I ordered the liporider plus below which should get me 2.4A I think that can likely get me full brightness single color, but ideally I’d like to be able to go full brightness white. Or full white with sk6812.
I can’t find anywhere where the liporider states that it has over discharge protection. So I should probably get BMS to protect from that as well.
Is there a cheap efficient way to step the 3.7v up to 5v and maintain high amps to run this at full brightness? The battery pack can certainly handle it, it just seems like most of the boost converters are for small amps.
3s1p is also an option, I think I’m my research, I decided stepping up voltage was better in this case?
Also I was trying to build this one a budget to some degree, that’s partially why I picked the liporider. I just have to imagine there is a cheap safe option that I am overlooking.
