I’m currently building a small lamp-in-a-jar project for my 5 year old niece, similar to this Dream Jar. Instead of using a matrix, I’m just going to wrap some WS2812B tape around some sturdy tube roll, shove a USB battery pack and a D1 mini inside the tube, and mount a single LED-illuminated arcade button to the lid for control. I’ll use cotton balls or some kind of light diffusing material between the LEDs and the plastic jar.
I would like the button to turn on WLED, enable a semi-random preset, and then turn off (or better yet fade out) after 60 seconds or so. I’ve managed to get the arcade button’s LED illuminated by connecting it to WLED’s relay pin, and have toyed around with a custom usermod and such to successfully turn on/off WLED and cycle through my presets with the button.
My main questions are:
1: How best to manage power, so that when the lamp is not in use, it is not drawing excessive juice? Since this is button activated exclusively, I would like the D1 to go into as deep a sleep as possible and only wake up when the button is pressed.
2: And related to question #1, how do I code (or just configure) WLED to turn off 60 seconds after it turns on? Ideally, I need to completely turn it off, not just put it in standby mode for maximum power savings.
Thanks in advance for any direction in answering these remaining questions, and any other suggestions or ideas are appreciated!
