Abnormal Lighting of SM16825
For the light strip using the SM16825 chip, the color and brightness of the LED change each time the settings are saved. This chip requires support from the subsequent 32-bit current gain and other configurations. However, no UI interface for setting these parameters has been found, and the power-on results vary each time. Additionally, after saving the set length of the LED, the brightness and color of the light strip also differ each time.
Who can tell me how to set up and use it normally?
