API white color temperature for RGB leds
In the browser UI there is a slider for setting the white color temperature which also works for RGB led strips. I tried to create a preset to emulate this slider with the api command ‘W=~10’ but it does nothing. So I figured that this command works only on led strips with an extra white channel. So how can I create the same effect as the slider on RGB strips, but with a preset that I can bind to a hardware button?
Maybe to put it in other words:
Is there a preset macro possible that advances along palette colors the same way that there is one that increases the brightness or cycles through presets?
