is there any user mods that make the 1d act like 2d martix?
Yes, there are user modifications and setups that can make a 1D LED strip behave like a 2D matrix in WLED. Here are a few approaches you might consider:
1. Matrix Configuration
- Segmenting: Define your LED strip in WLED as a 2D matrix by segmenting the strip into rows. For example, if you have a strip of 60 LEDs, you can configure it as a 10x6 matrix.
2. Custom User Mod
- User Mod Code: If you’re comfortable with coding, you can modify the WLED firmware to implement matrix behavior. This involves manipulating how the LED data is sent to create the illusion of a 2D grid.
3. Using the “Matrix” Effect
- Effects Library: Some versions of WLED have built-in effects designed for matrix-like behavior. You can experiment with these to see if they meet your needs.
4. Community Resources
- WLED Forum: Check the WLED GitHub or community forums for user-contributed mods. Some users might have shared their code for matrix-like behavior, which you can adapt.
5. ESP32/ESP8266 Libraries
- Adafruit NeoPixel Library: If you’re coding, consider using libraries like Adafruit NeoPixel or FastLED, which offer advanced features for controlling LED matrices.
Example Configuration
In WLED, configure your LED setup in the segment settings. Set the total number of LEDs, then adjust how they are laid out in the segment, treating it as rows and columns.
This should give you the effect you’re looking for! If you need more detailed guidance on specific setups or coding, just let me know!
