Hi.
I have added an INMP441 and configured WLED.
The sound display sometimes seems “off” in that the strip doesn’t light up in ways I would expect based on the music playing.
I pulled the microphone out while the system was live to swap it with another one for testing purposes.
When the microphone was completely disconnected, the LEDs continued to animate as if there was a sound input.
I need some help confirming what is going on:
Option 1: The PINS being used for the microphone are now floating, leading to the spurious animations. This only happens when the microphone is not attached, and is therefore not evidence of a messy signal causing strange animations when the microphone is attached.
Option 2: This is evidence of interference on the data line. In this case, the interference is present when the microphone is attached, and that would be a reason for the strange animations when the microphone is attached.
Option n: Something else I haven’t thought of (I’m fairly new to WLED).
Looking forward to comments…Thanks
Brendon
