Hi
I installed WLED Beta 0.14-1b via the web install. I created a simple playlist from just one preset to play for 10 seconds and then to go solid as the end preset. I set it to repeat just 1 times but when I save it, it saves it to repeat 2 times. If I save it to repeat 2 times it save it to repeat 3 times, and so on. Basically you can just set the repeat number one below and it will be fine (ie if you want to repeat 3 times, set to 2), but if you just want to repeat 1 times you can’t (setting it to repeat 0 times make repeat indefinitely).
I installed release 0.13.3 and this issue is not there and everything works as it should, so is defiantly a bug in the beta 0.14-1b build.
Thanks Kal
