WLED .13 I cannot find cycle preset
I had a perfectly working Christmas Tree and Star (2 segments) and about 40 presets defined on WLED .11
I took the leap and loaded WLED .13 and I cannot find cycle preset anywhere, where I can say boot up and start cycling sequence 1-40. Help would be appreciated… I’m ready to go back to older but I assume its better to be on the latest.
Tim
It has been removed and replaced by playlists.
It can take a long time to add 40 presets using the playlist editor.
You can make a new preset, uncheck “current state” and plug this in. Modify the duration if you’d like, example is 3 minutes (1800 10ths of a second)
"playlist": {"dur":1800,"transition":7,"repeat":0,"ps":[1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40]}
thanks for that suggestion … i will give that a try when I get home
not sure why the previous simple method was not maintained for backward compatibility
i was unable to find any documentation on playlists or the removal of cycle preset …is there ?
This is not to say I dont LOVE WLED…it IS awesome!
After figuring out the playlist feature, I do LIKE it… it will make for more flexible sequences…
gotta get better at dealing with change : )
