I am not sure if this is the correct place to report bugs to be seen and prioritized for correction. If someone here knows where/how to get that done for these items I appreciate the assistance.
I have tested both of the following items in 14, 15 release as well as 16 alpha. This is not hardware reliant, as I have used/tested with four different hardware builds and I am confident of that because of the number of different devices I am testing with.
In the app when I switch between devices/instances/nodes the name at the top of the app does not match what you are using, example I use device “wall left” and switch to “wall right” and it still shows “wall left” but controls wall right. I am always having to check nodes to determine which one I am actually about to change.
Data from some effects settings do not get received with sync unless you turn on segment options and that does not seem to be the correct sync item that data should go with as it clearly is effect data.
Thank you in advance for any assistance!
