I will be using lots of WLED controllers in an upcoming project and ideally need to set the SSID and password from their defaults of WLED-AP and wled1234 at firmware level so that they are set when we flash each ESP8266.
I’ve tried all the obvious places in the code with no luck.
Can anyone help. Thanks in advance.
Nick
This may be helpful
wled.h contains the default username and passwords that can used if you wish to hardcode in an AP and password.
+++++++++++++++++ from wled.h
#ifndef CLIENT_SSID
#define CLIENT_SSID DEFAULT_CLIENT_SSID
#endif
#ifndef CLIENT_PASS
#define CLIENT_PASS “”
#endif
Just add these to near the top of your wled.h
#define CLIENT_SSID “YourAP”
#define CLIENT_PASS “Yourpass”
(or create a my_config.h text file and add the settings to that file)
At the top of wled.h you will find.
//uncomment this if you have a “my_config.h” file you’d like to use
//#define WLED_USE_MY_CONFIG
Thanks very much.
Nick
