I’m using WLED for the first time. I bought an Athom controller pre-flashed with WLED (from AliExpress). Without LEDs plugged in, I can get into the UI no problems. However, once I plug in a string of WS2812B lights, I can no longer connect after powering on. If I refresh the app (by dragging down), it then shows as offline. If I unplug them and refresh, it’s back online.
I get the same sort of behaviour when I add the Home Assistant integration. Without LEDs plugged in it shows up, but once plugged in, the lights go unavailable in HA.
There was also one point where the first LEDs (maybe 30?) were flashing red, but I don’t know how to reproduce that. I also bought a couple of Athom bulbs pre-flashed with WLED, and they’re working fine.
Any help would be appreciated. Since I’m new to this, I’m not sure if there’s further info that would help.
