Correct pins for APA102 LEDs on ESP8266
Please let me share some insights on how to configure WLED on an ESP8266 with APA102 LEDs connected.
I am not an expert, but thanks to awawa-dev (developer of HyperHDR) I was able to dramatically improve the frame rate with which HyperHDR/Hyperion is sending information to WLED and from there to my Ambilight-LED stripes.
Background was, that I could not increase the frequency inside HyperHDR higher than 20 fps. I am steering 302 APA LEDs and higher rates made WLED completely unresponsive. I was using GPIO2 for data and GPIO04 for CLK. It turned out, that with this set-up WLED was running in a “software SPI mode” which was limiting performance and the frame rate to 20.
For “hardware SPI” on the ESP8266 you need to connect GPIO14: SCLK for the CLK and GPIO13: MOSI for data. I can easily go up to 50 fps in HyperHDR now, even I understood that WLED is limiting to 42 Hz maximum.
Hope that may help others with their configuration.
Use GPIO2 for data and GPIO1 for clock. Ignore the rest.
Hello blazoncek
thanks for your feedback!
Actually, I tested several combination of GPIOs, but not the one you are mentioning. I will give it a try.
I also recognized that it is documented like this in the “getting started” .
I might get old, but I could swear it looked different in the past.
It was GPIO2 and GPIO0 in the past.
I just spent a lot of time trying to figure this out too. I needed to connect 98 APA102s AND WS2812Bs at the same time.
I tried every GPIO pin and mapped it accordingly
I tried different boards/strips/wires
No matter what, those frigging APA102s would not do ANYTHING
I kept digging through what other people have tried.
I then found THIS fork - WLED_0.11.1_ESP8266_APA102.bin
Then it struck me… I hadn’t tried to flash any other builds of WLED onto any of these boards.
I WAS using - soundReactive_WLED_0.12.0_ESP8266.bin
I then flashed the APA102.bin version to my board and it was as easy as selecting the type of LED and which pins they were connected to. FINALLY!
SO then I said F it - I downloaded the newest version of WLED 13.0 B5 ESP8266
Flashed to my D1 Mini and guess what… that one works too!
2 Things to Remember:
1. Don’t ever use pin D2 on a WeMos D1 Mini for anything (for it is reserved for FLASH)
2. If all else fails, TRY ANOTHER BUILD :wink:
