Hello, looking for a controller for some leds with arduino I came across this fantastic project! Today I received the esp32 wroom and some led strips to test it (because I only have arduinos…) and I liked it a lot!!
I have thought of a couple of things that could be added (if possible… since it is one thing to think about it but another very different thing to create) and another thing is to assume that you have not already thought of them…
The first is to have a soft start effect of the leds as if it were a fade but in which you can choose the time you want it to take to reach maximum lighting (for example from 0 to 10 seconds) and once it has reached to the maximum stay fixed.
The second is that you could choose the number of inputs/outputs by indicating a number or adding them in the same way as the outputs for the LEDs with a +, so if you are missing inputs, you don’t have to modify and compile the program again.
As I said, it may be that you have them in mind, but hey… I’d rather sin by repeating it than by not saying anything…
Thanks to all the team that has racked their heads to do this!!! Greetings!
PS is translated by google.
