Fade out lights when powering on
Hi, im doing a project in my car and i run into a problem.
Im trying to make the LEDs turn on similar to the lights in the car, so, when I have power for the esp board (starting the car) I want the LEDs to turn on and fade out for a period of 5 seconds.
Seems like I can’t figure out how to do that…
Would be happy to see if someone else has done it before.
I would suggest you experiment with the Fade or perhaps Dissolve effects to get the approximate timing you want.
You can then use a Playlist to “bracket” that effect with the start colour/brightness you want and then finish with colour brightness you need.
