Hi, I’m setting up WLED to drive a Cronixie clock and I saw that the usermod Readme says “Make sure the Auto Brightness Limiter is enabled at 420mA”. Where does that value come from?
Hi welcome
you shoudt set the MAX to 2/3 of your board or PSU
the value in the readme is from the max LED used in this Projekt
the Controller ((in this Projekt)) is capable of 650mA SMD
if you use a ESP8266 like D1 WEMOS you can go to 850mA without PSU
this can drive at nighttime around 250LED brightness 25-50
the WLED will take care on the Value and Brightness
