stop working: led strip stay on even during WLED reboot, changes from WLED webui are not acknoledged by led strip, etc
A close look at ESP board show me this:
cables from led strip to power supply were… melted (especially GND one).
Do you think is just a cable issue (I should use thicker cables) or are any other attention points to consider?
Please let me know what do you think…
Thanks,
-f
You might want to use heavier wire. It is hard to tell from the pic but your wires on the strip look like they are stripped a bit long. Are you sure they could not have touched one another and or some other metal object? I would put some heat shrink over them next time or some hot glue. Definitely add a fuse between the strip and the power supply on the +.
Do you use White a lot? I don’t think you would smoke the wires unless something shorted or you were using white.
Easiest: I would use a 15a automotive fuse. and wire that can support at least 15a
-Ideally using the limiter in the config set on 10000 and a 12a fuse, but you will have a hard time finding 12a fuses unless going with glass tube type.
100% go with heavier wire if you are mostly using white.
