I have 2 strips 24 v 2.5 meters each i plan to use in a project. My question is. Is this possible with the dig uno? I think so based on what i read. Is there a special way they need wired to the board? Looking for a video or somthing explaining how to do this properly. If not i need a quad i guess .
That shouldn’t be an issue.
Double check with the quinled.info web site, but I’m pretty sure they handle 24V out of the box these days.
Those boards have proper levelshifters for 2 outputs so you can either use 2 GPIOs (one for each strip) or a single (connect the strip data in series).
The wiring diagram on the quinled.info site shows connections for a 12V strip.
That should be identical for 24V, just a 24V PS is required.
Ty. Do i need to make any changes to the board in order for the second output to work? Or does it come ready? Ty
Should be ready to go, just configure WLED.
All this should be in the quinled.info docs.
