So I have a dig quad, for a while I only had one channel running with ws2811 strips. It was working great.
I had some strips from a different brand that I wanted to set up on another channel, tested the strips to make sure they worked and they did just fine, but once I got them installed and wired up, both of my channels started going crazy.
I checked all wiring and it is fine, I have ground loop properly connected solder points are fine.
But now when I disconnect channel 2 completely my original set that was working great is now still spazzing out.
Also, when I use the wled on off button, the strips stop spazzing but they don’t lose power, leds are still on. Which makes me worried I ruined my dern dig quad board.
What did I do wrong? Do I need to now try to repair damaged sections of the original strips?
