Digital clock effect
Is it possible to use the “scrolling text” effect and leave only the digital clock?
And so that the hours and minutes are located vertically (or this could be changed), I use a 16x16 matrix.
For an example of what I mean:
Yeah , example in discord start here Discord
Make two segments in your matrix , select scrolling text effect and in one segment change the name to “#HH” and the other to " #MM"
Thanks for the answer.
When I change segment names. “#HH” and “#MM” are scrolled and overlapped. That is, hours and minutes do not apply.
But #TIME work correctly, but there is scrolling and unnecessary seconds.
Unfortunately the discord link does not open. Perhaps some other settings are needed?
Join discord and look in the custom-fx channel WLED
Yes, thank you, I read all the messages, unfortunately it did not help. Perhaps the reason is the controller I use (NodeMCU V3). The date and time never appeared. I only see #HH and #MM on the matrix (but not the real date and time)
What version you are testing with and i will try to replicate on esp8266
Updating from firmware 0.14.0 → 0.14.1 helped, thanks again :slight_smile:
Cool , not sure you mean helped it work if so then great if not this is my setting
