I Dorn want to skip the first led
I dont want found a solution for something.
I only noticed if i Set LED settiing from 0 6 to 1 6 then the last LED (physicly) LED 6 turned of.
I noticed that and ask the question if this is correct and logical. IT seems like IT is correct but not directly logical.
I understand now. You were testing things and saw something strange, wanting to know if it was normal.
Since WLED expects segment 0 to start with led 0, having it start at led 1 is not currently supported shall we say.
I could be wrong. @Aircookie might have time to explain it further if you need to know. Since your WLED system is operating the way you want, and you only did it for testing, I don’t think it is a big problem.
You Hit the nail on the head:)
Yes i found this Was Not logical cause i initially thought that what i did should turn of first and not last LED. @Aircoookie perhaps can explain it for ever body in an easy way so that others Are not wondering as i was wondering initially.
