I think 0.14 may have broken railway effect. Can any else test?
Please file a bug report on Github.
at my setup it still work
how ?
Any new info on this? Do we know why the effect broke?
Have you opened an issue on GH?
Just did.
Any update on this?
yes, waiting for your feedback.
but it may take some time as I’m taking a break from WLED.
Just trested on 13.3 and 14.0 again.
I’m pretty sure because you changed the behavior where an LED does not turn off when a new command is sent down. That broke it.
Old behavior the LEDs will flip flop back and forth being on and FX changes speed and SX changes the transitioning. example. LED 1 is on for 1 second then turns off and LED 2 turns on, this then repeats.
So on 0.14.0 the LED’s that are state 1, do not turn off when state 2 turns on. So the effect does not work as intended.
Nothing is telling LED 1 to turn off.
Please post a video comparing 0.13 to 0.14.
Here you go.
Railway.zip (5.5 MB)
Select palette “Colors 1 & 2”.
So? Did it help?
I will test tomorrow. Still seems like somewhat of a bug. Cause my preset works in 0.13.3 but not in 0.14.0. But I will take the fix if thats all it is, none the less.
This seems to have worked. THANKS!
I just will have to change my presets to the colors 1 and 2.
