I have managed to build a two ESP32 wled system:
- Master: works with the ALT display+ encoded rotary+audioreactive mic. It is set to Master (Sync)+Sends data via UDP
- Slave: receives via UDP and it is synced to receive changes from the master
Everything seems to work stable, changing the effects/presets/etc/etc to the master via the GUI the slave picks up the changes.
I would like to use this installation without the need of mobile phone, that’s why I built the display+rotary.
However, the slave ESP32 does not pick up the changes from the rotary of the master. The rotary works fine and changes the effects/presets/etc on master but the slave does not change/follow. Only if I get in the GUI I can sync the changes from the master to the slave ESP32.
