I have two ESP32s each controlling 300 LEDs in three segments with 100 lights per segment. When I sync the two, my effects on the primary ESP32 work great, but the secondary ESP32 doesn’t retain the segments. Is there a way to do this?
Test by adding the other one via ddp just to compare , worked fine in our test and it may also depend of your network setup
Check if you have segment options synced.
Sync settings.
