Update!! I just reflashed the Latest Nightly build of (regular Aircookie) 14.1 with Audio Reactive and AudioReactive is working with my Analog Max-9814 mic. So it should work for you ![]()
Flash using a PC and usb cable. Don’t do OTA
I can also confirm it is reacting at 40dB mic setting as well as 50dB setting. 60dB is not so good. Likely that 40 is still the best (my mic is wired with a 3 way switch so I can choose between 40,50,60dB).
