Hi everyone, I’m using version 0.14 of WLED with audio reactive enabled. I have connected a MAX4466 microphone to the ESP32 device, wired to pin 26. I’ve enabled the audio reactive function and set pin 26 as the analog microphone. Unfortunately, it’s not working. I noticed that in the WLED audio source settings, it’s still showing digital. How can I change the input?
The MAX4466 is a very poor mic. If you want analog I would switch to a MAX9814
Also make sure you installed the firmware from a pc and not with OTA.
I made a few posts on this here: ESP32 + MAX9814 not possible
